Regular diff oil wt vs slipperential oil wt
FormulaZR
Regular diff oil wt vs slipperential oil wt -
09.03.2014, 09:40 PM
So...easy question. Do I run the same weight of oil in the slipperential as I run in my regular diff - or does it need to be thicker/thinner?
FormulaZR
Find all posts by FormulaZR
2
RC-Monster Mike
Site Owner
09.04.2014, 09:50 PM
The same oil can be used. Internally, the diff is still a diff.
RC-Monster Mike
Visit RC-Monster Mike's homepage!
Find all posts by RC-Monster Mike
3
FormulaZR
09.04.2014, 10:12 PM
Ok thanks. I didn't know if the slipper function made it necessary to run a heavier or lighter weight oil to have the same handling.
FormulaZR
4
RC-Monster Mike
Site Owner
09.05.2014, 11:18 AM
The slipper works independently of the differential - if you run a LOT of slip you may go slightly heavier, as slip generates heat. I use 5k in my buggy and 10k in my truggy with the Slipperential - same as I used to use with a regular diff.
RC-Monster Mike
5
FormulaZR
09.05.2014, 12:47 PM
Perfect. Thanks for the answers!
FormulaZR
Linear Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
