RC Monster
Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Baja 1/5 Scale E Conversion Kit
jcflyer
Baja 1/5 Scale E Conversion Kit - 04.24.2016, 11:52 PM
Anyone have any trouble with their kit? I got one last week went to build it and the screw holes are drilled wrong!!! Gonna call Mike tomorrow!!
04.25.2016, 01:35 AM
Post up pics. You might have something the wrong way around
jcflyer
04.25.2016, 08:14 AM
I don't have anything the wrong way, it only fits one way. The screw holes for the diff are just off a bit plain and simple...
04.25.2016, 09:55 AM
There is a lot of flex in the chassis until everything is bolted tight. I remember having to keep most screws fairly loose until everything in place.
If it's not that ping Mike
jcflyer
04.25.2016, 10:13 PM
Ok I tried everything and took measurements the front two holes are 1/2mm off. There is no getting around it, if you try to enlarge the big square hole then the two rear screws won't line up. Another plate is what's needed with the holes in the proper place!!
nitrostarter
nitrostarter's Avatar
04.25.2016, 11:13 PM
Pictures??
N. Rustler conversion
jcflyer
04.25.2016, 11:15 PM
Trying to post them now!!! They doing repairs to the site now can access!!!
jcflyer
04.25.2016, 11:51 PM
Pics of the bottom plate!!!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.26.2016, 10:37 AM
That is definitely not the stock rear diff case - I propose that the issue is likely in the other part, as I am certain my cnc machine didn't simply decide to place the holes incorrectly this one time after making the same part for years. Maybe there is something else in the way? I see the mis-alignment in the picture, but I am certain the plate is the same as every other lower plate I've made since making this kit the 1st time several years ago.
jcflyer
04.26.2016, 11:05 PM
Ok got the problem sorted out with help from Monster Mike!!! Thanks brother, turns out it is the Turtle Racing transmission case causing all the problems.
The holes are all out of whack!!!
nitrostarter
04.26.2016, 11:53 PM
Thumbs up!
RC Monster
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
